› Fóruns › Específicos › Plataformas › Estressado? Pegue o Drone e vá pescar!
- julho 25, 2012 às 2:05 am
Coming Soon – AutoPilot Kontiki
The Kontiki Predator will soon be available with patented AutoPilot technology to maximise its potential to travel straight off-shore. Want to be kept informed? Sign up to our email newsletter and we will email you as soon as the AutoPilot Kontiki is available.
Nature?s design
Registered Design #411447 © Fishtex 2009
- The Predator?s unique natural shape with tail fin is designed to sit low in the water and dive under the breaking surf to maintain perfect direction.
- Superior natural shark stealth design cuts through the water with less resistance (for both launching and retrieving). Have a think about this – the shark shape has been well tested and proven for millions of years!
- The Predator range includes 3 motor thrust options: 30lb, 44lb & 54lb. Your choice to suit your conditions. All fit with salt water motors
- Easy to use on your own or with friends or family
- Perfectly balanced for best performance and handling, loading into vehicle etc Perfect power to weight ratio; very fast through the water
- Range up to 2.3km offshore
- A real head-turner: the Predator looks very smart
- 24 month Predator Kontiki warranty
- 12 month battery warranty
- The light weight Predator weighs from only 12kg with batteries
- Fully waterproof resin-encased reliable electronic timer. Use a magnet to adjust settings or the top mounted switch.
- Very simple to operate timer: set between 5, 10, 15, 20, 25 minute timer, or set to ‘infinity’ to go until the battery level cut out
- Free sturdy accessory carry-all case. Holds tools & batteries etc
- The natural tail shape works with the rudder to keep the Predator on course in rough conditions
- Batteries are mounted well forward to keep the motor in the water under full power in rough seas
- A ?KIWI ORIGINAL? – designed and made in New Zealand
- Off-set tow point to counter the torque of the motor
- The Predator control unit monitors power consumption and provides protection to the electronics and batteries. If anything snags blades from turning the motor is stopped 3 times and restarted, if snag still exists it will turn off and stay off.
Each Kontiki Predator comes with a free accessory case.
Dimensions: L1310 x H500 x W415mm
Download a PDF of this information and more – click here
Fonte: http://www.fishtex.co.nz/kontiki-predator-longline-fishing-nz-product-list/kontiki-predator/
