› Fóruns › Equipamentos › HobbyKing Quadcopter Control Board V2 (Atmega168PA)
- setembro 27, 2011 às 2:10 pm
A HK lançou a KK V2 (agora com o Atmega168PA), sendo possível voar Hexa, Y6, Y4 (que não era possível na sua versão anterior por falta de memória).
Eu particularmente gosto bastante da KK da HK pelo custo beneficio para hobby.
Based on the popular and already well supported KK Control board, the Hobbyking Quadcopter control board is bringing Quadcopter madness to the masses with its breakthroughs in quality and price!
The HobbyKing Quadcopter control board uses Japanese Murata piezo gyros that are less sensitive to vibration than SMD type gyros and also features state of the art SMT manufacturing to ensure quality. This board also uses a user programmable Atmega168PA IC.
Specs.
Size: 50.5mm x 50.5mm x 23.5mm
Weight: 14.5 gram
IC: Atmega168PA
Gyro: Murata Piezo
Input Voltage: 3.3-5.5V
Signal from Receiver: 1520us (4 channels)
Signal to ESC: 1520us (4 ESCs)Whats is a Quadcopter Control board you ask?
The HobbyKing Quadcopter controller is a flight control board for 4 rotor Aircraft (Quadcopters). Its purpose is to stabilise the aircraft during flight. To do this it takes the signal from the three on board gyros (roll, pitch and yaw) then passes the signal to the Atmega168PA IC. The Atmega168PA IC unit then processes these signals according the users installed software and passes control signals to the installed Electronic Speed Controllers (ESCs). These signals instruct the ESCs to make fine adjustments to the motors rotational speed which in turn stabalises your Quadcopter.
The HobbyKing Quadcopter control board also uses signals from your radio systems receiver (Rx) and passes these signals to the Atmega168PA IC via the ail, ele, thr and rud inputs. Once this information has been processed the IC will send varying signals to the ESCs which in turn adjust the rotational speed of each motor to induce controlled flight (up, down, backwards, forwards, left, right, yaw).
Buddy: http://www.hobbyking.com/buddy.asp?code=E01DBA14-EB95-4F84-96B3-87C7422B1FAD
Já pedi as minhas! Vou testar com o FY-30
- setembro 27, 2011 às 2:42 pm
Puts… parem de abrir esses tópicos!!!!!!!!!!!!!!!!!!!!!!!!!!
acabei de comprar.. ( tinha comprado uma ontem no ebay) … esse hobby é FLÓRIDA… srsrsrsrsr- setembro 27, 2011 às 2:52 pm
Eu tinha comprado 2 da antiga que nem chegaram e comprei mais 2 da nova!
Quero experimentar a KK com o FY-30 para ver como fica a estabilização.
- setembro 27, 2011 às 8:10 pm
Vinicius, qual seria a função do FY-30 no sistema, pois a placa não não estabiliza o quad, a função não é a mesma.- setembro 27, 2011 às 10:28 pm
AdrianoEla estabiliza mas nao volta sozinho para a posição neutra (horizontal), com o FY-30 talvez volte.
Com o acelerometro se soltar o comando ela estabiliza . (me corrija se estiver errado)
é possivel usar com o FMA Copilot? tenho 1 parado aqui
- setembro 28, 2011 às 4:02 am
Sim é possivel estabilizar com o FMA, Flymentor, Co-PIlot, FY-20, FY-30, todos eles estabilizam os eixos X e Y, independente da plataforma, eles ficam entre o RX e a KK estabilizando através do sinal PWM que vai para o comando de aileron e profundor (leme é dispensável).Abs
- setembro 28, 2011 às 12:13 pm
Blz, o FMA eu tenho, o único problema dele e em dias nublados, em dias de sol ele é perfeito, uso ele no modelo de EPP FPV da King com a gopro na ponta, ele fica muito estabilizado. Mas vou pensar seriamente em comprar um destes para add no sistema, acho que é fundamental poder soltar os comandos e ele voltar sozinho ao “eixo”.
- outubro 17, 2011 às 12:47 am
Ola Vinicius
Vc ja testou esta placa V2 ?
Ja chegou a minha tambem , tenho a V1 com a versao 4.7, já existe algo melhor para a V2?
Rony
- outubro 17, 2011 às 1:34 am
Rony, testei agora pouco a v4.7 em um QUAD e achei a mesma coisa da V1, na verdade já esperava isso, pois oque muda de uma para outra é a quantidade de memória do CI.
A ultima versão é a v4.7 mesmo.
- maio 3, 2012 às 1:01 pm
Chegou a testar a KK com o FMA? Qual FMA vc tem, o CP4 ou o Copilot-II? Abraços
Adriano W disse:
- maio 3, 2012 às 2:04 pm
mudando um pouco o topico, vc poderia me dizer se da certo colocar 5 motores djo 920kv e 1 905kv tb dji no hexa funcionaria certo
obrigado
