Lipo Bateria Luminier Drone 12000mah 4s 20c Dji Tarot F450
Uma das melhores e mais confiáveis marca do mercado!
Details
Lumenier lipo batteries provide you with great performance for your multi-rotor airframes and planes. This lipo’s 20 “C” rating is well suited for multi-rotor applications by balancing performance and weight. This Lumenier lipo maximizes flight time with minimal voltage sag. The all black battery design with the Luminier brand will look great on any airframe!
This 12000mAh 4s battery pack is a great choice to power your professional aerial photography equipment. This battery packs a ton of power in a compact form factor, giving you the flight time you need on your heavy-lift aerial rigs.
Specs
Length
182 mm
Width
74 mm
Height
32 mm
Weight
940g
C-Rating
20c – Burst 40c
Connector
XT60
Additional Information
| SKU |
2451 |
| Manufacturer |
Lumenier |
| Discharge Plug |
XT-60 |
| Voltage / Cell Count |
14.8 Volt (4 Cell) |
| Battery Capacity (mAh) |
12000 |
| C-Rating |
20 |
Bateria com poucas cargas, em torno de 30 ciclos, sempre balanceada e guardada em Storage!
Obs: Sem querer o conector de energia xt60 bateu na retifica e teve um pequeno corte.
Nada que prejudique a bateria ou o conector, veja ultima foto.
Consegui Voo de 40 minutos com esta bateria utilizando motores de 360kv e Hélices de 17 polegadas!
Aproveite, so estou vendendo pois vou mudar para 6s!
Vendo por R$ 399 no Depósito
