› Fóruns › Compra e venda › MCFC kkmulticopter, waypoint, GCS, android, folowme, RTH, position hold, alt hond (vendo)
- maio 18, 2013 às 4:41 pm
Possuo 2 placas com gps e pretendo vender uma delas, quero vender a kk MCFC, veja seus dados abaixo, uma com mais funções e facilidade para programar, 18 tipos de multis, segue com placa GPS compass e serial usb adapter, placa nova, preço R$ 670,00 pretendo vender para não ficar com investimento parado, já que vou usar outra unidade no meu hexa pode se usar modulo xbee para telemetria ou outro via serial.
Specification of FlyCam MCFC
Dimensions : 50mm * 50mm * 11mm(W * L * H)
Mounting hole spacing and hole : 45mm*45mm
Weight : 16g
Motor or servo Outputs : Max12
Configurations : 18types of multicopter support
Tri,Quad,QuadX,Y4,Hexa,HexaX,X6,Y6,Y6T,Octo,OctoX,X8,TwinQuad,Single,Dual,Twin,Butterfly,Avatar
Power : 5 voltage from external BEC
Signal Output
Fast Pulse Width Modulated (PWM) signal output to accurately control external ESCs
Supporting S-BUS (Futaba)
Audio buzzer
LED indicator
Sensors
Digital 3-Axis MEMS Gyroscope
Digital 3-Axis Accelerometer
Digital Barometer
3-Axis Magnetometer
Camera Control
auto Pitch / Roll stabilization for Gimbal
Software
Pre installed the firmware
Serial port for firmware updates
Display output – FlyCam OSD board support
Autoflight – FlyCam GPS/Compass board supportFeature of FlyCam MCFC
Sensors
Digital Barometer
3-Axis MagnetometerMulticopter stabilization controller
it is able to be more stable flight
Gimbal stabilization function for roll and pitch
It is compatible with 2-axis gimbal
Supporting Futaba S-bus receiver
Compatible with 2.4Ghz
Altitude Hold
Care free(heading free)
GPS Function
GPS Care free
Waypoint flight
Follow me (with X-bee)
GPS position hold(it can be changed by stick)
Return to homeFlyCam MCFC Includes
FlyCam MCFC board
USB to Serial
Jumper cable (8 pieces)
LED/BuzzerMade in Korea.
- abril 10, 2014 às 9:04 pm
Olá, sim, porém eu estou a utilizando em um quadcoptero 450.
