Segundo as especificações do fabricante, não há saída de video.
Spec:
- Li Battery 280-300Mah, working time 2.5-3 hr
- 2GB Built In Memory (over 1 Hour record limit time )
- High performance MI
- USB 2.0 with PnP
- Recording file format: 640*480 MP4
- Photo file format:1280×960 JEPG
- 70 degree wide angle view lens
- Camera lens rotates 90 degrees
- Product weight: 28g
- Product Size?82*22*22mm
- Support the following OS: WINDOWS98/98SE/ME/2000/XP/Vista/MAS OS/ LINUX
- Software Included
Manual of Fly DV
- Turn on Fly DV: Press the ON/OFF button, the RED will be on. After 3 seconds, Fly DV is ready.
- DV Mode: Push the DV/DC button to DV, then Press the OK button. The Blue LED will keep flashing, frequency is 1time/2seconds, which means it begins recording; Press OK button again, Fly DV will save video file to integrated Flash memory, and BLUE LED will be off.
- DC Mode: Push the DV/DC The Blue LED will keep flashing, frequency is 1time/5seconds, which means it begins taking photo automatically and continually. (There is a ?Taking photo Time Setting? software in CD, you can set the intervals of taking photo, for example, take a photo every 15 seconds. The mininum intervals is 10 seconds, Max is 300 seconds.) Press OK button again, Fly DV will save these photo files to integrated Flash memory, and BLUE LED will be off.
- Fly DV will save DV/DC files automatically when the power is low, then turn it off.
- The RED LED will flash when charging, and will keep lighting when fully charged, please charge it with AC adapter, PC can?t charge this Fly DV fully
- 2GB flash is optional
- Get and open Video /Photo files by connecting Fly DV to PC via USB cable.
- Get the PC time to Fly DV, Connect Fly DV to your conputer via USB cable, Run the TRCTool.exe as the guiding, then restart the Fly DV.
- High performance MIC
- USB 2.0 with PnP
- Support the following OS: 2000/XP/MAS OS/ LINUX
- Frame rate: 25Fps
