› Fóruns › Equipamentos › Novo Radio Turnigy 9XR
- dezembro 26, 2012 às 3:50 am
Pessoal lancamento fresquinho da HK o novo radio Turnigy
Promete ser muito util para fpv pois pode ser usado modulos de 433Mhz
So tem um probleminha que vai ser comprar esse radio em apenas 3 horas depois do lancamento
Ja estava em Backorder. Vai ser o unico jeito de comprar ele.
Eu gostei muito do design dele bem diferente principalmente com respeito a antena que foge da tradicional haste.
Confiram:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=31544&aff=171252
The greatly anticipated Turnigy 9XR has arrived!
The software for the 9XR first began development 6 years ago. Since then it has been tweaked, tuned, changed, updated and revamped by members of the R/C community into a powerful – yet easy to use interface. Our engineers designed the physical product around the R/C communities software changes and input. The culmination of all these is the Turnigy 9XR!
For many users this will be the perfect 9 channel radio straight out of the box, but there are many tinkerers out there who love modifying and pushing the boundaries of what is possible from their radio. We have factory fitted the 9XR with an AVR ISP header to simplify the development of custom software, we have launched turnigy9xr.com as the epicentre for software developers and additional community support for all 9XR users……With the 9XR we encourage it!
The 9XR is supplied preloaded with top quality software which is full of features and yet remains easy to use. Our aim was to develop a radio for you, the hobbyist, with an extensive list of standard features usually expected from a radio system 3 times the price. Our Turnigy 9XR is everything you imagined and more!
9XR Standard Features:
? 8 Channel PPM/9 Channel PCM
? Full Ball Bearing gimbals
? Adjustable Stick Length
? Digital Trims on all Primary Axis
? 16 Model Memory
? Assignable Switches
? Freely Assignable Channel Mixes
? Graphical Dual Rate and Exponential
? Sub Trim and Travel Adjust
? Flaps and Differential
? Throttle Hold
? Supports Heli/ Aero/ Glider Model Types
? Programming Templates Based on Model Type
? Supports M1, M2, M3, M4 stick modes
? 128 x 64 backlit Liquid Crystal Display
? Built in JR & Futaba Trainer Ports
? PPM & PCM Output
? JR Form Factor RF Modules (Orx Dsm2, Orx Open LRS 433Mhz etc)
? Programmable Timers
? Low Voltage Warning and Buzzer
? Supports 3s Lipo (Required)
? 9XR Firmware Pre-loaded
? AVR ISP Interface
? Internal 2.4GHz AntennaOnline support and user forums available at: http://www.turnigy9xr.com
Spec:
Channnel: 8ch ppm/9ch pcm
Display: 128*64LCD (Backlit)
Support Type: Heli/Acro/Glid
Model Memory: 16
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer: YesRequired:
Battery 3S Lipo
RF ModuleIncluded:
Turnigy 9XR Transmitter (Mode 2 ? Throttle on Left Stick)
Quick Start guideNote: This version is supplied without an RF Module, Please order the relevent RF module from the accessories list below.
- dezembro 26, 2012 às 4:24 am
Já comprei um em “Backorder”, vamos ver quando eles vão colocar em estoque.
- dezembro 26, 2012 às 10:05 am
Pelo que percebi, as únicas diferenças são a capa externa, o firmware que já é atualizado e o backlight. Fora isso, tudo igual!!!
Tb, ganhou conectores Futaba e JR, mas continua com apenas uma chave de três posições.
A parte boa é o preço. Igual a versão anterior.http://www.hobbyking.com/hobbyking/store/__28297__Turnigy_9XR_Transmitter_Mode_1_No_Module_.html
- dezembro 26, 2012 às 10:08 am
…e quem já tem modulo UHF como eu, se ferra todinho, pq a alça onde se fixa a antena é de plástico quadrado e grosso.
- dezembro 26, 2012 às 11:34 am
Pra isso eu tenho uma solução bacana, uma repetidora de 2.4 para 433, mais tarde eu faço um tópico sobre o projeto.
Sergio Saldanha disse:
- dezembro 26, 2012 às 12:14 pm
Poxa vida, nas imagens da interface dá para ver que ela é 100% idêntica ao firmware ER9X.
- dezembro 26, 2012 às 12:45 pm
- dezembro 26, 2012 às 1:31 pm
Como disse antes… Pegar um rádio atualizado para o ER9, com Backlight e uma mexida no externo, pelo mesmo preço do original 9X com firmware original, sem backlight e sem as novas entradas JR e Futaba, vale a pena.
- dezembro 26, 2012 às 9:36 pm
- dezembro 26, 2012 às 10:17 pm
sera que tem chaves de 3 posicoes? bem legal a ideia de ter todos padroes, vai pegar o mercado…
- dezembro 26, 2012 às 11:05 pm
Tem uma só, igual ao Turnigy 9X V2 original.
- dezembro 27, 2012 às 12:42 am
Eu esperava mais….
- dezembro 27, 2012 às 2:35 am
No meu 9xer antigo fiz alterações para obter a telemetria no LCD usando o Frsky, será que o novo já possui ?- dezembro 27, 2012 às 2:36 am
