› Fóruns › Equipamentos › Recall WK-M !!Não voar com a antena V2 (toda branca)!!
- outubro 22, 2012 às 8:43 pm
DJI FINDS FIRMWARE BUG CAUSING SPONTANEOUS S800 SYSTEM FAILURE
Research and testing confirms zero faults with S800 air frame ? error found in compass firmware
DJI, one of the world?s leading developers and manufacturers in UAV systems, today announced a voluntary recall of all WooKong-M GPS compasses purchased after June 15th, 2012. The new compasses? firmware contained a bug that, under very specific conditions, could send an erratic signal causing a spike in power and overall system failure. DJI confirmed both the fault and the bug fix by flying four S800s under heavy burden on electric tether for more than 72 hours without failure.
Since learning of the system failures during several S800 flights, DJI spent more than 1600 man hours in research and testing to determine the fault and develop a solution for customers. Through the vigorous research process, DJI engineers not only fixed the bug in the firmware, but also developed multiple new innovations for the WooKong-M GPS compass.
In turn, DJI is also developing a new firmware upgrade for the WooKong-M IMU based on the innovations developed for the compass bug fix. The IMU firmware upgrade will be released within the next several weeks and will have superior solutions for the following: better resistance to vibration, less white lights and better compass tracking. A further announcement will be made when this firmware enhancement will be available.
All customers with WooKong-M GPS compasses purchased after June 15th, 2012 should click here to get information on returning their GPS/Compass module for firmware upgrade. Until users of large multi-rotors (S800 size and larger) fitted with post-June 15th compasses complete the GPS/compass recall, DJI highly recommends not flying to eliminate the potential of system failure.
DJI is excited that the company not only discovered the fault and developed a fix, but also created a superior firmware in the process. The company looks forward to working with all customers to quickly replace their affected compasses and get everyone back in the air.
Old GPS Module (OKAY TO FLY):
New GPS Module (NEEDS NEW FACTORY FIRMWARE):
Como ninguém tinha postado ainda, é bom ficar o alerta e esperar as antenas V3
- outubro 23, 2012 às 9:40 am
Mazza, tenho um wkm, você voa ele sem o GPS, não tem problema.
- outubro 23, 2012 às 10:48 am
Mazza, estou querendo usar 4s no meu wkm dji 450, pois com a hélice 10×4,7 no modo manual com 25% de motor tenho somente 5,5 amp de consumo, no entanto, quando coloco no modo atitude, ele não aceita a curva de motor do rádio. Por acaso sabe como resolver isto.
- outubro 23, 2012 às 11:55 am
No software, onde.
- outubro 23, 2012 às 1:06 pm
Já vi esta opção, ele reconhece automático.
- outubro 24, 2012 às 1:54 pm
Pessoal, noticia boa para que tem WKM… Abaixo copia do post do foram e-voo ( flycam)
Dessa vez parece que não teremos custo do recall.
__________________________________________
Para iniciar o RECALL, basta entrar no site oficial DJI, efetuar o cadastro de RECALL.
http://www.dji-innovations.com/compass/submit_rma/
Em seguida a própria DJI irá redirecioná-lo para o email ***** editado pela moderação *****, então informaremos o procedimento para darmos continuidade ao processo que será bem simples.
O único custo que os clientes DJI terão é do envio até nosso endereço, daí para frente a DJI assume todos os custos.
Missão cumprida, custo quase ZERO se comparado ao RECALL anterior, este foi nosso principal objetivo.
- outubro 24, 2012 às 4:12 pm
Pode enviar para a Flycam, seguir o procedimento do sites deles.
É seguro, eu conheço a equipe deles.
- outubro 24, 2012 às 5:27 pm
Mauricio,
Issa parceria com a Flycam foi fechada ontem.
