› Fóruns › Compra e venda › Vendido Conjunto ImmersionRC EzUHF com rádio
- fevereiro 4, 2015 às 12:08 pm
Conjunto Composto:
– ImmersionRC EzUHF Receiver, 8 channel diversity
– EZUHF JR Module Transmitter
– 433MHz Nagoya Dual Band Swivel Antenna
– Radio Turnigy 9XR Transmitter Mode 2
– Bateria Lipo para o rádio
Details
Reliable FHSS Link (Frequency Hopping, Spread Spectrum)
433MHz/70cm Ham band operation: 112dBm Sensitivity
Bi-directional ready (contains onboard transmitter)
Diversity Antenna configuration
ceramic filtered inputs, eliminates nearby high-power video Tx interference
Mikrokopter mode, emits PPM on a chosen channel
Vehicle mode, couples two chosen channels (ideal for coupling steering servos on monster trucks)
USB Connection for easy firmware upgrades, and advanced configuration
Standard SMA antenna connectors, compatibility with standard 433/70cm band antennas
8 standard servo connectors
Failsafe, preset by button on the EzUHF transmitter
EzLink connection to a EzOSD, providing in-flight display, and telemetry down-linked parameters:
RSSI Ant 1, Ant 2
Frequency Error
SNR for each freq. bin
Link QualityEZUHF JR Module Transmitter
DetailsA long-awaited module, compatible with most radios which use the ‘JR’ module standard, including the 9XR, and the new Taranis. Same features as its big brother, but without the cabling, nor external batteries.
Features
500mW of EzUHF Power
JR Module, compatible with the Hobby King 9xR, and the FrSky Taranis
Headtracker port, capable of powering a headset
Highlow power switch
100% compatible with all EzUHF Receivers
GFSK modulation
Standard SMA antenna connector, compatibility with 70cm antennas
Standard USB port for firmware upgrades, and system configuration
Single pushbutton learning of failsafe positions
Binding function, which allows binding Single Tx>Rx, Multi Tx>Rx, and Single Tx>Multi Rx
Mates with all EzUHF receivers
But there?s more, as all EzUHF products feature a USB connector which, in combination with our application software, will allow you to set up your receivers in just the way you like. Mikrokopter mode, the cloning of channels, diagnostics, firmware updates, etc. etc. all available with the click of your mouse or a press of a button, no soldering required, nor any fancy nonstandard cable. Convenient, simple and intuitive, leaving you with more time to enjoy your flying, rather than spending hours or days setting up your equipment.All of that and many, many more upcoming features which further allow integration of our products and turn the electronics powering your FPV plane into a reliable, rock solid, but above all a plug ?n fly solution that you get to enjoy every time you fly.
Specifications:
Frequency: 144/430MHz
Gain: 2.15db / 3.0db
Max power: 10Watts
V.S.W.R: Less than 1.5
Impedance: 50 OHM
Connector: BNC
Length: Retracted 135mm / Extended 370mm Weight: 44g
- fevereiro 4, 2015 às 12:55 pm
Amigo tenho interesse apenas no rádio…. caso vc encontre alguem que qeira só UHF… ai fica bom pra nós.
- fevereiro 4, 2015 às 12:56 pm
Vamos ver o que acontece. Obrigado.
- fevereiro 4, 2015 às 1:16 pm
so pra complementar… radio+bateria
- fevereiro 4, 2015 às 1:26 pm
Leandro Santos disse:
faça uma proposta
- março 5, 2015 às 11:27 pm
amigo qual o valor ?
