[VENDIDO] Módulo FrSky para Turnigy9X e JR + RX de 8 canais
Fóruns Compra e venda [VENDIDO] Módulo FrSky para Turnigy9X e JR + RX de 8 canais
    Moust
    Vendo módulo FrSky novo para rádios Turnigy9X e JR.
    Alcance: 1,5 – 2,5km
    Fotos reais:
    FrSKY ACCST technology is proven, approved by many model associations, tested and reviewed as the leading Chinese 2.4Ghz R/C Technology. If you think DSM2 or FASST is the best, think again!
    New FrSKY ACCST (Advanced Continuous Channel Shifting Technology) gives you secure radio communicatios in 2.4Ghz band. ACCST 2.4GHz system shifts 80 channels around hundred times per second in the 2.4GHz band. This means that the system is completely resistant to interference in that band.
    Features:
    Advanced Continuous Channel Shifting Technology (ACCSTis our advanced tecnology it shifts channel hundred times per second and there is no signal conflicts and interruptions) robust frequency agility.
    Easy to bind and very fast link-up.
    Excellent reboot time.
    True Diversity with two antennas.
    All channels can be programmed with Failsafe, quickly and easily.
    Quick and extremely stable in performance.
    Precise and smooth servo response.
    Extended range (1.5km-2.5km).
    FrSky DJT is compatible with JR transmitters following:
    JR: 347, 388, 783, U8, PCM10, PCM10S, PCM10SX, PCM10IIS, 8103, J9303, PX, 9XII, 11XZERO
    Receiver Specification:
    Operating voltage: 3.0~16V(HV Version)
    Power consumption: 30mA
    Resolution: 3072
    Latency: 22ms
    Number of channels: 8
    Range: 1.5km-2.5km
    Dimensions: 44 x 24 x 14 mm
    Weight: 9.3g
    Module specification:
    Operating voltage: 6.0V-13.0V (can handle 3S!)
    Power consumption: 50mA
    Output Power:: 60mW
    Resolution: 3072 (11bit)
    Dimensions: 63.9×48.5×36.5mm
    Included;
    1 x 8-channel Telemetry Transmitter Module DJT
    1 x Transmitter Antenna
    1 x 8-channel receiver V8FR-II (HV Version)
    * Transmitter Module is compaitble with all V8 NON-telemetry Recievers
    VENDIDO
    Bruno222
    O louco! Vai colocar UHF no seu Quad, Moust? Haja bateria!
    sky
    Passa o link do mercado livre
    Moust
    Hhhauhauha não Bruno, vou usar o Frsky mesmo, é que estou com 2 kits
    sky, ainda não anunciei no MercadoLivre. Se quiser comprar com o MercadoPago pode fazer o pagamento sem ter o anuncio. É até melhor pois se eu anunciar lá o valor ficará um pouco mais alto devido à comissão do MercadoLivre
