› Fóruns › Compra e venda › {VENDIDO} QUAD S450 DeadCat, Defiblilator, Mt2213
- novembro 20, 2015 às 12:11 pm
QUAD S450 DeadCat, Defiblilator, Mt2213-935kv e Afroesc Simonk Esc Afro 30a
Link Mercado Livre: http://produto.mercadolivre.com.br/MLB-724160839-quad-s450-deadcat-defiblilator-mt2213-935kv-e-afroesc-simo-_JM
A NAZA não acompanha!!!
Valor: 600,00
- Dead Cat Conversion Kit for SK450 Quadcopter Frame
- SK450 Dead Cat “Defibrillator” Power and A/V Distribution Board and Power Shield
- SK450 Dead Cat “Defibrillator” Power Shield (Without Main Board)
- Motor Mt2213-935kv Multistar Combo 10-4.5 Cw -ccw
- Afroesc Simonk Esc Afro 30a P/ Multirotor Drone
Are you looking to convert your SK450 quadcopter into a flying dead cat? If so, we have just the thing! This kit allows you to convert your standard SK450 into the “Dead Cat” style configuration with or without (your choice) the mess and hassle of mounting your own dead feline to the frame.
In addition to flying your deceased family pet around at home or your favorite local flying site, this configuration is also ideal for aerial video/photography as the front arms offer an extra wide field of view. The integrated camera mount plate located at the front of the frame is perfect for mounting a GoPRO or similar sized camera.
This kit includes everything necessary to convert your SK450 quad frame into either a wicked camera rig or a morbid dead pet mobile, the choice is yours!
*Note: This is a conversion kit only and requires the use of original SK450 frame parts to complete.
Specs:
Front arm width: 490mm
Rear arm width: 375mm
Weight: 460g (completed frame w/out electronics)
Includes:
Lower main frame plate
Upper main frame plate
All necessary hardwareSK450 Dead Cat “Defibrillator” Power and A/V Distribution Board and Power Shield
We pulled out the defibrillator and shocked some serious life in to the Dead Cat conversion! The Spider style Quad-Copter was already awesome with its optimized arm angle and layout for a propeller free FPV view. And now the much awaited progression to an integrated power and A/V distribution board and plug in power shielded.The new lower board has direct solder pads for the motor ESC power lines right at the base of the arms and power ?in? pads located directly above the battery to minimize cabling. There are power connector?s at the front, back and middle for your FPV gear and flight controller, all tied to the power shield which effortlessly supply?s a regulated, filtered and RF Noise shielded 5 volts at a whopping 3 amps for the camera and flight controller and 12 volts at 1 amp for the hungriest of video transmitters. The video connectors at the front and rear also not only supply the voltage but also carry the audio and video signal from the front mounted camera to the rear mounted video transmitter. This upgrade will save you weight, clean up your layout and improve reliability by reducing connection failures. I guess this Dead Cat has 9 lives after all!
Features:
? Integrated power distribution
? Wick style solder pads
? Camera and video transmitter integrated wiring
? 3 or 4 cell input
? SMPS converter with RF noise protection shield
? Thermal ProtectedSpecs:
Input voltage: 8-16v (3-4 cell lipoly)
weight: 142g
output: 5V/3A and 12V/1AMotor Mt2213-935kv Multistar Combo 10-4.5 Cw -ccw
Procurando um motor para o sistema de energia final para o seu próximo projeto Multi-rotor? Não procure mais!
Os OutRunners Turnigy Multistar são projetados com uma coisa em mente – a maximização do desempenho Multi-rotor! Dispõem de high-end ímãs 45SH, rolamentos NMB de alta qualidade, 14 polos, montagem de motor personalizado e todos são precisão equilibrados para o bom funcionamento, estes motores são projetados especificamente para uso multi-rotor.
O 2213 integra o adaptador de suporte na caixa do motor para o problema de livre penhora prop e centralização. Ambos ranhura (estilo DJI) e helices padrão pode ser utilizado, por isso, não mais danificar o seu prop. O 2213 foi construído em alumínio de montagem para uma instalação rápida e fácil em seu quadro de multi-rotor. Este kit Multi-Star vem com dois adereços 1045 um CCW e um CW e é ideal para uma 3 celulas set-up para um tamanho de 450 Quad, 550 ou 700 Hex Octo. E para aqueles que forem usar bateria 4S , configurar e pode-se usar hélices 8045 para uma resposta ultra-rápido.
Estes OutRunners Multistar foram especificamente projetados a partir do zero para uso multi-rotor e não são baseados em motores de avião.
Spec:
KV (RPM / V): 935
Células Lipo: 2-4s
Max Surge Watts (W): 200
Max.current (10s): 15 Amps
Sem carga atual: 0,4 ampères
Intemo Resistance: 0,180 ohm
Número de polos: 14
Dimensões (Dia.xL): 27,9 x 25.7 mm (sem contar com o eixo propulsor)
Motor Shaft: 3 mm (não o eixo propulsor)
sustentar eixo: com fenda estilo (DJI) rodada 8mm (7 milímetros plana para flat) desceu a 6mm e uma porca M6 prop
Prop: 10 x 4.7 (3 células) (780 Gr) 8 x 4,5 (4CELL) ( 850 Gr)
Peso: 55g
espaçamento furo passante: 16mm * 19 milímetrosAfroesc Simonk Esc Afro 30a P/ Multirotor Drone
Specs:
Current Draw: 30A Continuous
Voltage Range: 2-4s Lipoly
BEC: 0.5A Linear
Input Freq: 1KHz
Firmware: afro_nfet.hex
Discharge wire/plugs: 15AWG/Male 3.5mm
Motor wire/plugs: 16AWG/Female 3.5mm
Weight: 26.5g (Included wire, plug, heat shrink)
Size: 50 x 25 x 11mm
- dezembro 23, 2015 às 2:42 pm
Up…
