Vendo Controladora Quadcopter FF Free Flight
Fóruns Compra e venda Vendo Controladora Quadcopter FF Free Flight
    É uma excelente placa, a estabilidade de vôo dela se compara a controladora FH-X46 para quem conhece sabe do que estou dizendo, e esta placa FF Free Flight vem com controle de Gimbal (camera) de Tilt e Roll ótima para FPV.
    *Vendo por motivo que estou montando um Hexacopter e essa placa é so para Quadcopter.
    Valor R$ 200,00
    Descrição:
    – 100% brand new free flight controller, four axis Free Flight FF Auto Balance Controller,it can be used without debugging.
     – Support 8 channel PWM input and Six channel PWM output
    – Adopts three axis digital gyroscope and three axis digital accerleration sensor.
    – Auto-balance,quadcopter X or+mode
    – Support commercial ESC and I2C ESC,Practical free flight controller
    – Support aerial photography and Dual axle stabilization PTZ
    – with beep function when voltage is lower than 10.8V
    – this free flight controller recommend work with GWS 3-blade paddles or other high performance balance paddles Wire Connection:
    – Input CH: 1, Aileron/ flap 2 Lift and down 3,accelerograph 4,Heading Direction 5,Remote control calibration( Switch channel)  6,PTZ pitch angle 7, PTZ pitch angle trimming(ratio CH input)
    – Output CH(PWN): 1, PTZ Pitch angle servo 2, PTZ roll servo, 3, No.1 motor input 4,No.2 motor input 5, No.3 motor input 6,No.4 motor input Dual axis PTZ:
    – It maintains verticality mode under 6CH Auto-mode.It can be trimming by button 7 to adjust angle.
