Produto Mercado Livre 729704805
This is the airborne module only which is used in conjuction with the Arkbird-AAT Auto Antenna Tracker System.
This unit is perfect if you wish to kit out more than one model with the antenna tracking system which is also available from HobbyKing? (see related items). This unit is plug and play when used with the popular Arkbird OSD unit.
Specs:
Input Voltage: 7~13V (2~3S lipoly)
Max Current Draw: 200mA@12V
Dimensions: 65 x 30 x 10mm
Weight: 12g
Atenção este anuncio é somente do Airborne module
