Vendo Fpv Arkbird Aat Auto Antenna Tracker System
Fóruns Compra e venda Vendo Fpv Arkbird Aat Auto Antenna Tracker System
    Nova na caixa, nunca usada, motivo da venda desemprego, recebida a pouco, abaxei o preço novamente……
    R$ 1.300,00
    Moçada posso fazer a 1.300,00 lançado como usado no ml, para evitar taxas  caso alguem tenha interesse procure no ML o anuncio a 1300,00 ( é nova nunca usada)
    Produto Merc Liv  #739627219
    http://produto.mercadolivre.com.br/MLB-739627219-fpv-arkbird-aat-auto-antenna-tracker-system-_JM
    Arkbird-AAT Auto Antenna tracker and Airborne Module combo set also inlcudes, at no extra cost, an Arkbird GPS module, so you’ll never get lost on those long distance FPV flights again!
    An auto antenna tracker is a must for long distance FPV/Video operation and ensures the maximum reception at all times by tracking the model as it flies in all directions and altitudes. The Arkbird AAT greatly improves the transmission range by pointing a high gain ground panel antenna (not supplied) at your model wherever it goes. This antenna tracker has an airborne module which works in conjunction with the popular Arkbird OSD unit (also not supplied) and installation is straightforward and simple as it comes plug and play, no soldering required.
    The tracker has 2 sets of sensors for dual-coupling correction and is equipped with a magnetic compass and inertial navigation compass (gyroscope) for high precision tracking. Also includes 2 channel transmission of the video and audio for dual reliability (50Hz on video channel, 10Hz on audio channel).
    Take off point coordinates can be automatically saved after powering up, dynamic positioning is achieved by using the supplied GPS interface in the ground module which supports the movement tracking. This is very handy if the antenna tracker is used on a moving vehicle or in the event of an emergency landing or searching for a lost model.
    The ground unit is supplied with integrated suction cups for mounting on a car roof etc and a tripod mounting so that you can choose which way you mount the tracker whilst its in use.
    Features:
    ? Improves long distance transmission
    ? 2 sets of sensors for dual-coupling correction
    ? Plug and play when used with Arkbird OSD
    ? High quality powerful steering motor with 360° slip ring
    ? Advanced fully automatic calibration algorithm for one step calibration
    ? 2 channel transmission on video and audio
    ? Dynamic positioning can be achieved with the included GPS interface
    ? Dual mounting, suction cup or tripod
    ? Self adaptive GPS Baud Rate which is compatible with all kinds of FPV equipment
    ? USB interface for upgrades
    Specs:
    Input Voltage (Ground Module): 12V (3S lipoly)
    Max Current Draw (Ground Module): 800mA@12V
    Input Voltage (Airborne Module): 7~13V (2~3S lipoly)
    Max Current Draw (Airborne Module): 200mA@12V
    Dimensions (Ground Module): 160 x 160 x 120mm
    Dimensions (Airborne Module): 65 x 30 x 10mm
    Weight (Airborne Module): 12g
    Included:
    Arkbird ATT auto tracker ground module with mount
    Arkbird ATT auto tracker airborne module
    GPS interface
    Pre-wired airborne module wiring harness
    A/V lead with 6 pin connector
    12V power lead with XT60 connector
    2 x inline adapters
    UP
    teve algum problema com a AAT ?
    camera NTSC funcionou corretamente ?
    Ola Fabricio, esta é nova,comprada a algum tempo como mais alguns itens, e recebida a apenas tres dias, ainda esta na caixa, não foi montada, na época que comprei esperava dar um upgrade na minha groundstation, mas como fiquei desempregado a pouco, tenho outras prioridades, infelizmente se eu vender………….depois mais para a frente compro outra.
    Nova na caixa lacrada nunca usada, R$ 1.580,00 abaixei para o preço de custo, motivo desemprego.
    Amigo vende separado?
    UP
    UP
    me add como amigo vamos conversar sobre a antenna
    feito.
    Sérgio Cruz disse:
    nada ainda
    Marcelo Andriolo disse:
    feito.
    Sérgio Cruz disse:
    estou enteressado
    AEROJEQUI
    ainda está a venda? vamos negociar?
    to tentando mais ele não responde
    Ops.ola, desculpe não havia visto, o tracker ja foi vendido, obrigado, vou dar baixa neste.
