› Fóruns › Compra e venda › Vendo itens fpv novos
- dezembro 1, 2015 às 12:10 am
Vendo :
Arkbird Autopilot System w/OSD V3.1020 (GPS/Altitude Hold/Auto-Level)
Anúncio #725593031 do ML (R$ 800,00)
RX de video diversity 8 canais – Skyzone 5.8ghz 8ch Diversity A/v Receiver W/dual Output
Anúncio #725602323 do ML (R$ 490,00)
TX de video 600 Mw 32 canais – Skyzone Fpv 5.8ghz 600mw 32ch A/v Transmitting (tx) Module
Anúncio #725636369 do ML (R$ 270,00)
Especificações dos itens:
Arkbird:
The Arkbird Autopilot System w/OSD is an all-in-one solution for your FPV model’s navigation. This unit is loaded with features such as GPS waypoint flight, “Return to Home” functionality, auto-leveling, altitude hold and much more! It utilizes GPS, barometer and attitude sensors to stabilize/control your model’s flight.
Worried about losing control of your FPV model when flying out of sight? With the Arkbird Autopilot System on-board there is no need to worry! The “Return to Home” function can be activated at any time to fly your model back to its take-off position and will be activated automatically in the event that your model flies out of RF range.
The integrated OSD system provides you with all of the information you need during flight such as altitude, flying direction, home direction, roll angle, pitch angle and time since take-off just to name a few. This system also includes a current sensor with pre-installed XT60 power plugs so you can monitor your model’s flight battery status via the OSD.
The Arkbird Autopilot System comes with everything you need to setup your FPV model for the ultimate in GPS based Autopilot flight. It features a “plug and play” design meaning there is no soldering or modification required to use. All power plugs and wire connections are pre-installed.
Features:
? GPS, barometer and attitude sensors to stabilize/control your model’s flight
? Integrated OSD functionality
? GPS based “Return to Home” functionality
? 4 point GPS waypoint flight
? “Cruise Flight” mode offering straight and level flight pattern holding
? Auto-leveling
? Easy to setup and adjust
*Note: See user manual located under the “Files” tab below for full features/specification for this system.
Specs:
Arkbird Autopilot controller
Dimensions: 50x38x14mm
Weight: 26.5gGstar R-15E GPS module
Dimensions: 44x34x12mm
Weight: 19gIncludes:
GPS module
Current sensor
All necessary connection cablesRX video Diversity
5.8GHz 8CH Diversity Receiver w/tracker link port, dual output.
Features:
? A/V receiver with diversity antenna inputs
? Tracker link port for direct link to an antenna tracker
? SMA antenna connectors, compatible with standard 5.8GHz antennas (omni or directional)
? Frequencies: 5705, 5645, 5665, 5685, 5885, 5905, 5925, 5945MHz
? Supplied with two 5.8GHz ?Rubber-duck? antennas
? Not affected by 2.4GHz R/C radios!Specs:
Input voltage range: 12V (3S lipo)
Dimensions: 76x64x18mm
Weight: 90g
Antenna connection: SMAIncludes:
5.8GHz diversity receiver
Power cable w/JST plug
A/V cables** Many fake, poor quality & untested FPV products are currently entering the market. Don?t get caught out with poor quality substitutes, SkyZone FPV equipment is tried and true and has been tested and developed by FPV pilots for FPV pilots.
SkyZone has forged a reputation of quality and reliability and has been tested and developed byFPV pilots for FPV pilots.
The TS832 Transmitter packs a whopping 600mW of ultra clean 5.8GHz power! A must for those looking for longer range and locked in video. The TS832 is transmitting a full range of 32 channels and uses an easy to use 2 button interface, it also comes with a clean pre-wired harness, and only weighs in at a scant 21grams, it?s Perfect for a wide range of aircraft!
*For best range and video link stability we recommend using the SkyZone 5.8GHz Cloud Spirit circular-polarized Antenna Set (SMA-RP) available below in the accessory?s tab
Features:
? 32 channels: Cover A, B, E bands and F bands
? Two switching buttons for the band and channel
? Two digits display for the band and channel
? Power off memory for last channel and bandSpecs:
Video format supported: NTSC/PAL
Antenna connection: RP-SMA, jack
Power input: 7.4-16V (3S Lipoly suggested)
Transmitting power: 600mW
Antenna gain: 2dbm
Working current: 220mA at 12V
Video bandwidth: 8Mhz
Audio bandwidth : 6.5Mhz
Weight: 21g
Dimension: 54x 32x 10mm(excluding antenna)
Frequency range:
FR1 5865,5845,5825,5805,5785,5765,5745,5725
FR2 5733,5752,5771,5790,5809,5828,5847,5866
FR3 5707,5685,5665,5645,5885,5905,5925,5945
FR4 5740,5760,5780,5800,5820,5840,5860,5880Quality Guarantee
We are receiving reports that other vendors are selling low quality counterfeit copies of this transmitter which have reduced range and high cases of drop outs. Completely unfit for purpose. Don’t risk your expensive rig with cheap transmitters, we stock the real deal!
