monitor usado poucas vezes..Monitor parado devido ao uso dos oculos fpv.
excelente monitor e imagem.
R$290,00
- Display
- 7″ 800×400 pixel LCD (6.9″ viewable)
- 400cd/m2 brightness
- Horizontal Frequency Range 30-60kHz
- Field Frequency Range 50-75Hz
- Dot Pitch 0.0736(W)x0.207(H)mm
- Display Ratio 16:9 (stretch selectable) and 4:3
- Contrast Ratio: 500:1
- Response Time: 15ms
- Viewing Angle 70o/70o (L/R) 50o/70o (U/D)
- Matte Screen
- Working Temperature: -20C-60C
- Storage Temperature: -30C-70C
- Power Requirements
- 6-18VDC (2s-4s lipo compatible)
- 7W max (1A power supply minimum recommended)
- Inputs (on breakout cable)
- RCA Male Video (NTSC/PAL Manually Selectable in Menu)
- RCA Male Audio (mono)
- 2.1mm Barrel Power Input (Various power adapter cables available here)
- Physical
- Weight including sun shield: .975 lb
- Outside dimensions: 7.2″W, 4.78″H, 1.37″D (181x125x35mm)
- Sun shield sticks out 4.75″ from front face, tapered to bottom edge
