› Fóruns › Compra e venda › VENDO O NOVO PILOTO AUTOMATICO FY-DoS
- abril 5, 2013 às 3:32 pm
ESTE PILOTO AUTOMATICO SERVE TANTO PATA AVIOES QUANTO PARA MULTIROTORES!
QUALQUER ACESSORIO DOS FY21AP QUANTO DO FY31AP SERVEM NESTE EQUIPAMENTO, O HORNET, O AP117 E SEUS GPS`s TAMBEM! TEM MODO 3D E HEAD LOCK COM HOLD ALTITUDE E O MELHOR DE TODOS É O “RETURN TO LAUNCH” RTL OU RTH.
PREÇO APENAS R$ 320,00 COM GUIA DE IMPORTACAO DA RECEITA FEDERAL.
DoS work alone function
? Deactivated Mode– In this mode, all control of the aircraft is by the pilot. The DoS does not participate in flight control. equivalent to ordinary RC remote control
? Stabilized Mode – DoS can automatically keep the level flight attitude in any weather condition. This makes operating the aerobat become very simple and easy for the beginner. When the pilots feel the plane out of control as long as stabilize the flight throttle, loosen the operating sticks, it can automatically recover to the level state.
? 3D Mode – Help stabilize flight attitude, will try its best to keep loosen sticks attitude flight, make the flight more smooth, easy to do all kinds of special action.
? Fixed altitude and Heading lock flight Mode – can lock the flight course and maintain the flight height. Loosen the operating stick; the plane can automatically keep flight course, at the same time lock flying height, automatically correct flight course deviation, easy to operate.
? Auto Circling Mode -Plane will keep the current height, at a certain turn rate hovering flight (look up, a counterclockwise circle), but it will not hover around a fixed point, and may be away from the original hovering point because of the wind.
DoS connect with GPS module function (GPS NOT INCLUDED IN THIS VERSION!)
? Fixed Altitude And Heading Lock Flight Mode – Can lock the flight course and maintain the flight height. Loosen the operating sticks; plane can automatically keep flight course, at the same time lock flying height, automatically correct flight course deviation, and begin straight line flight. Easy to operate
? Auto Return To Launch Mode(RTH) – In the Auto Return To Launch Mode, aerobat will automatically return to the course reversal point, keeping the current height, and it will hover after arriving the target point.
? Auto Circling Mode-When activated in this mode, the plane will immediately fly in a circle( look up , clockwise hovering). The centre of the circle is the point of activation.The plane will hover keeping the current height, The hovering radius can be set, and the default circle radius is 80 meters.
? GCS Software ?Operator can set flight parameters, monitoring and recording flight path etc through the GCS software in the computer(This requires connecting the data radio) .
New function:? Flight Fencing ?Can set distance when is in recerceicer remote control, if your plane goes outside the fenced area then it will auto switch to GUIDED mode, and will fly back to a pre-defined return point and loiter there ready for you to take over again. You then use a switch on your transmitter to take back control .
More information please refer the DoS manual
The latest firmware for Multi-rotor flight system is V2.0 can realize the following functions:? Attitude Stabilized Mode – Dos can auto stabilize the aircraft flight attitude in this mode, pitch and roll stick center position for 0 °attitude,its endpoint is 45 ° , pitch and roll stick can linear control the flight attitude, maximum angular velocity is 150 ° / s. Yaw stick in the center position will lock current course , its endpoint corresponding maximum rotation rate 135 ° per second, yaw stick can linear control the aircraft rotation rate. Throttle stick direct control aircraft climb and decline, climbing and declining rate is directly related to the throttle.
?Fixed Altitude Flight Mode – In this Mode, pitch, roll, yaw control method is the same as Attitude Stabilized Mode.DOS can auto control flight altitude.Climbing and descending rate is directly related to the throttle, when the throttle stick is in the center position,DOS auto locks the altitude, in maximum means climb rate is 3 m/s, in minimum means decline rate is 1.5 m/s.Throttle stick can linear control the aircraft climb and decline rate.
- julho 17, 2013 às 5:29 pm
Outro modulo gps serviria pra ele ou somente o que é vendido? vi que a conexão é igual a qualquer modulo tipo ublox, mtk… etc. Sabe qual o baudrate do gps original ? sabendo isto creio que daria pra conectar outros. Tenho certo interesse mas preciso saber se dá pra conectar outro gps.
()S
- agosto 31, 2013 às 3:50 am
Já vendeu?- janeiro 22, 2014 às 10:15 am
Ola Marcelo, voce ja vendeu o FY-DoS?
