BOM DIA PESSOAL, SEI QUE NÃO É FÓRUM DE VENDA, MAS VEJO TODO MUNDO ANUNCIANDO PRODUTOS OU TROCAS ENTÃO APROVEITEI PARA VER SE ALGUÉM TEM INTERESSE
Estou vendendo meu Monitor FPV de 7 polegadas com RX Embutido:
Features:
-Built-in 5.8G Receiver
-None “blue screen” effect when signal is weak
-Small, light weight, durable
Specification:
1. Screen size:7?
2. Screen type: TFT LCD Screen/long life, LED backlight
3. Resolution: 800*480
4. Brightness: 450cd/m2
5. Contrast: 500:1
6. View Angle: 140/120degree (Horizontal/Vertical)
7. Working Voltage: DV 7-13V(center positive) or 11.1V Li-battery
8. Power Consumption: < 6w
9. Size: 170mm x 110mm x 40mm
10. Built-in 5.8Ghz receiver (RC305 5.8G)
11. Input: 2 ways video including AV1 for built-in receiver, one way audio
12 Output: 1 way
13. Support 9 languages menu selection including English.
14. Working temperature: -10¿~+ 65 ¿
15. Receiver antenna connector type: RP-SMA, jack (monitor side)
* The manufacturer may use same packing for several different types of products, please disregard the discrepancies (if any) on the packing.
Working frequencies (* Check your TX frequency to make sure they are supported by your TX)
? CH1: 5705MHz
? CH2: 5685MHz
? CH3: 5665MHz
? CH4: 5645MHz
? CH5: 5885MHz
? CH6: 5905MHz
? CH7: 5925MHz
? CH8: 5945MHz
Acompanha:
? Monitor 7 Polegadas com Receptor 5.8ghz
? Protetor de sol
? Bateria Lipo 1800mah
? Antena Omni original
OBS: Produto seminovo com 3 MESES de uso. Não acompanha caixa original e antena Helicoidal
R$ 590,00 (NEGOCIÁVEL) ou troco por baterias 3S de 5000mah ou superior.
Região de Campinas-SP
