› Fóruns › Compra e venda › [vendo] Syndrones X8 Heavy Lift
- março 15, 2016 às 9:53 pm
Produto novo, nunca usado.
Vendo Syndrones X8HL, octacóptero 980mm
Ideal para levantar gimbal com Canon 5d, Panasonic GH4, etc…
Acompanha 8 motores Foxtech W4830 370KV
Valor R$3000,00
Aceito propostas.
Fotos do produto
Fotos de um já pronto para vôo
The Syn-X8 HL is designed for serious professionals. The X8 motor configuration provides a much more stable platform for heavy-lift requirements. The X8 configuration is well suited for your hi end pro cameras.
All Syn-X8 HL Frames come fitted with a power distribution mounting plate.
Features
Vibration Dampened Gimbal Plate
All our frames come equipped with our special 3mm thick vibration dampening camera gimbal plate designed to fit a wide variety of camera gimbals. We also provide separate plates for the DJI Zenmuse Z15 and Zenmuse H3-2D. It comes pre-fitted to the center frame and includes an anti-vibration system used to remove unwanted high frequency shakes and ?jello?.
Loads of Space
Space is not an issue on a Syndrone frame. Our large multi-level center plates are large enough to pack all your electronics with extra space left for future installments and upgrades.
GPS Tray
The GPS tray is conveniently situated to mount your compass and GPS module away from any electrical or magnetic interference.
Battery Trays
Large dual battery trays are located on either side of the center plate for perfect balance and CG. Removing the battery placement from the conventional top of center plate frees up more and provides for battery redundancy.
Simple To Assemble
Our frames are assembled and tested at our factory before being shipping. All that?s required when you receive your new frame is to attach the booms to the center plate and tighten the stainless steel screws.
Super Strong Frame
Diamond Weave extra strong carbon fiber booms for our SYN-6 HL, SYN-X8 and SYN-8 HL. 1.5mm Thickness on the boom hulls, stainless steel screws and strong white G10 boards for the center plate, gimble plate and motor mounts.
Motor to Motor 980mm
Material Diamond Weave Carbon Fiber, White G10 Plates, 2mm Base Mount Legs
Recommended Setup: Axi4120 Motors, 16inch Xoar Props, Hobbywing 70Amp ESC?s, DJI Wookong-M, 2 x 10000mah 6s 40C Batteries
